Modify the OIR for Lifecycle
  • December 10, 2025
  • 7 replies
  • 289 views
Version: Windchill 13.0
Use Case: How can we modify the OIR to add a condition that if it is a design view it should follow lifecycle XYZ and if the view is A or B Or C it should follow the lifecycle EFG?
Description:
Best answer by ASP_000000001
using the following tags i was able to achieve in OIR
<AttrValue id="lifeCycle.id" algorithm="com.ptc.core.foundation.lifecycle.server.impl.LifeCycleTemplateAttributeAlgorithm">
<Value algorithm="com.ptc.windchill.mpml.algorithm.ViewToLifeCycleAlgorithm">
Fadel
23-Emerald II
December 10, 2025
for view its not gonna work in the newest releases , you can do it based on other attributes
https://www.ptc.com/en/support/article/CS396081
Buiꓘa
But i am looking for the view based one. Can the view attribute used in this solution ?
Fadel
23-Emerald II
December 16, 2025
Buiꓘa
Community Moderator
December 16, 2025
Hello @AP_10483126,
It looks like you have a response from a community expert. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
