Sep 12, 2018 8:18 AM UTC
Monitoring database host using PTC System Monitor
I'm using Windchill in our environment. Currently testing PSM 6.0 to monitor environment. Things are working as expected so far though I still need to learn more on administration of PSM. Question is how can I monitor database host of Windchill?
Since I installed PSM agents in Windchill application server, the agents are also monitoring properties of host like CPU, Memory, etc. I am able to add database connection in PSM and thus monitor transactions, but how can I monitor host properties of database server as well?
Thank you,
gafoorgk12-AmethystAuthor
Sep 17, 2018 7:53 AM UTC
It is confirmed that there is no way to monitor disk, cpu, memory of database server using PSM with default licenses in it. Additional host monitoring license must be purchased from Dynatrace for this.
