more date parameters questions
&PTC_WM_CREATED_ON
&PTC_WM_MODIFIED_ON
When I look at values for these date parameters above in my parameter list they each show a different date...Which is correct. They are different...as most of them would be.
*BUT - When I enter these parameters into a drawing note they both display the created on date.
Even though the modified on date is different.
Also - The modified on date doesn't update anymore. I started using this last week and I'm pretty sure that field would update & should the date of the previous check-in each time the drawing was checked out.
What could cause these dates to display the same date even though they are different dates in the parameter list?
Mr. Tracy Willis
&PTC_WM_MODIFIED_ON
Mr. Tracy Willis
