Patriot_1776
Jun 18, 2013 6:04 PM UTC
More lost data, more crashes. The hits just keep coming.......
Lost a couple days work. Yay. Have had to reboot the system probably 15 tims or more in the last 1-1/2 days. It turns out Windburn handles family table very poorly, especially when trying to copy them in the workspace. I copied the family table assembly, carefully renaming the instances so there wasn't any issue. Then I deleted the entire family table. That worked, but then when I wanted to delete the instances from the workspace, the HAL 9000 system told me I had to delete the generic. The system failed to either delete the instances from the Workspace (best solution) or even break the link between the files. So, again, I'm having to go outside the system to back up the assembly to a network drive, delete the entire family table, then bring it into the workspace.
Excuse me, but would it be too much to ask to have the system we paid a TON of money for, actually work as advertised so I don't have to keep using a network drive to get the job done? SRSLY?????
Jun 18, 2013 6:13 PM UTC
One of the BIG issues that we learned about, which is undocumented, is that Windchill cannot handle any family tables that contain asterixs. It floored me that this essential, time saving tool was omitted from Windchill functionality. We've since had to go back through our thousands of family tables to make sure all of the asterixs were converted to values, and we have to constantly remind users that this convenient functionality cannot be used in Pro/E. If you're running into corrupted family table files on Windchill-Pro/E transfers, check the tables for asterixs.
6-Contributor
Jun 18, 2013 6:27 PM UTC
Deleting instances is cumbersome, but this should work:
- Open the generic
- Open all the instances
- Return to the Generic, delete the family table
- Save the generic. You should see a message stating the instances are no longer table driven
- Save each of the instances that are currently in session
This process will make the instances stand-alone so they can be deleted.
Patriot_1776
Jun 18, 2013 7:55 PM UTC
Ok, I tried something COMPLETELY different. I was going to back up the family table generic assembly to a network drive, then rename the assembly on the network, open the assembly, delete the entire table, then save it, thus saving it to the Workspace without the instances.
I found a much better and easier way, again, going outside the POS system: Simply do a "Save a Copy" in Pro/E in the generic model. You now get this popup window that allows you to select any models you want to reuse or copy, I just reused everything. When it copies the file, it does not copy the instances, so there is no family table to delete. you save it and then it's a new file in the workspace. Done.
And so, the best way to work in Windburn is to.......avoid using it when possible.
Patriot_1776
Jun 18, 2013 7:15 PM UTC
Thanks guys, I'll have to look at that. I REALLY hat this software. I wish I had my Intralink that had none of these issues.....
Mar 28, 2014 3:18 AM UTC
I know this is just about a year old, we identified this same issue, little sad if you ask me that PTC makes Creo so dependant on windchill and makes Creo work so well with family tables but yet windchill cant deal with family tables properly.....
however we did find a solution, we have been working with a developer for a differerent issue and they provided us with a Library wizard tool that takes family table parts and strips the generics out and checks the generics into windchill. Best solution to the problem so far, www.dandq.ca is the developer's website, program we have been using is Control's pro studio. I would email them for a demo
Patriot_1776
Mar 28, 2014 1:39 PM UTC
Thanks for the info Graham, I'll look into it!
Mar 28, 2014 1:49 PM UTC
no problem, its a frustrating problem. so I figured I would mention a possible solution
