Feb 11, 2026 2:42 PM UTC
Moving Windchill 13 VM to New Host
Hi. We are currently planning to move our Windchill Virtual server to updated Nutanix hardware. To do this, we need to change the IP address of the server itself. No other changes are being made. Can you tell me if you can foresee this IP change having any negative effect on the operation of the Windchill application? Thank you.
18-Opal
Feb 11, 2026 3:01 PM UTC
Hi @SF_9820819,
When you mention “move,” I would consider that to be a rehost of the application.
In that case, the application would need to be rehosted.
avillanueva
23-Emerald II
Feb 11, 2026 3:13 PM UTC
No, IP address change should not be an impact. It should just be a DNS update or your hosts file on the VM is recorded there.
