May 26, 2014 11:19 AM UTC
Mozilla browser
We've recently been using the embedded mozilla browser due to what seems like constant ie/windchill annoyances. One of my users sent me this, does anyone have any advice?
> The Mozilla Browser is not working to “Collect Related Data”. For example, if I select a generic model for checkout I should be able to collect all the related instances of that model, but when I try the interface just sits there spinning . . . . . . other users have experienced the same thing.
Ian Bagnald, CISSP
Sr System Support Analyst
Jun 12, 2014 2:05 PM UTC
Couple of things,
I recommend don't going to java 1.7. Stay with Java 1.6.0_45 or higher. Second, what version of IE are you on. Google Chrome plug-in may help. Just make sure in your IE options, your active X is all enabled and your java securities are at the lowest. Also, IE options, general, settings, check for new version, is set to every time I visit the web page.
I had many of discussions with PTC technical support with calls, and all of them told me to stay away from Java 1.7.0. until 10.2. It is just too many issues to deal with. After you have installed Java JRE 1.6.0_45 on all the clients, you have to change the clients registries so that Java JRE doesn't auto update on the clients.
Good luck,
Patrick
In Reply to Ian Bagnald:
Ian Bagnald, CISSP
Jun 12, 2014 2:13 PM UTC
If some of your clients are still using Windows XP, IE 8 is the highest. And yes, some clients stil use XP even though Windows has stopped placing patches on the OS since last April.
Good Luck,
Patrick
Ian Bagnald, CISSP
