6-Contributor
Nov 24, 2025 1:51 PM UTC
MPMlink--process plan , 如何在process plan中导出一个产品 站位的所有零部件信息及数量
Version: Windchill 13.0
Use Case: 如何从一个产品的process plan的某个站位,例如本案,OP 0020. 导出所有该站位使用的零部件信息及其数量
Description:
如何从一个产品的process plan的某个站位,例如本案,OP 0020. 导出所有该站位使用的零部件信息及其数量,至某个文件中。谢谢
Emeritus
Nov 27, 2025 11:13 AM UTC
Hi @JW_7580554,
Thank you for your question.
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Best Regards,
Vivek N
Community Moderation Team
Nov 28, 2025 11:06 AM UTC
Greetings from India.
You can use "Generate Work instructions", it will export all the Consumed Parts, resources, Operation Instructions (If you do that in Creo/Illustrate).
try that please!
Best Regards
Hari
Emeritus
Dec 2, 2025 3:48 AM UTC
Hello @JW_7580554,
It looks like you have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
