6-Contributor
Aug 25, 2025 8:41 AM UTC
MPMLink - Work Instructions for technological operations
Version: Windchill 13.0
Use Case: How Work Instructions in MPMLink can be utilized for technological operations (milling, turning, cutting etc.)?
Description:
Are Work Instructions in MPMLink designed to support technological operations (milling, turning, cutting etc.) or more suitable for operations regading assembling of final products/sub-assemblies? How to set other ilustrations than from Creo Ilustrate/Creo View in Work instructions? What are best practices?
avillanueva
23-Emerald II
Aug 25, 2025 5:21 PM UTC
I would think the latter since you are writing procedures for humans. CNC would be best for the "tech" operations you described but if there were many steps, you can document and attach the code to run.
