MS is crashing
Recently I have rehosted one environment and after that it was starting up but from yesterday I am facing problems with startup of windchill pdmlink applciation.
when I start I am getting below lines .. and finally it stopped ..
2014-11-07 08:26:43,504 INFO [main] client.wc.service.DistributedSupportService - Using DataServer de-s-0174792.de.abb.com@4099[0]
2014-11-07 08:26:43,519 INFO [main] client.wc.service.imex.ImExServiceImpl - ImExServiceImpl : Start performStartupProcess()
2014-11-07 08:26:44,377 INFO [main] wt.method.server.startup - Classification Service started successfully.
2014-11-07 08:26:57,895 ERROR [WVSScheduleQueue.SchedulingThread] com.infoengine.log.debug Administrator - com.infoengine.exception.adapter.IEAdapterIOException; nested exception is:
javax.naming.NameNotFoundException: [LDAP: error code 32 - The search base entry 'uid=admin,ou=people,cn=Windchill_8.0,cn=Application Services,o=a' does not exist]; remaining name 'uid=admin,ou=people,cn=Windchill_8.0,cn=Application Services,o=a'
at com.infoengine.jndi.QueryObjects.run(QueryObjects.java:276)
at com.infoengine.jndi.JNDIAdapterImpl.processRequest(JNDIAdapterImpl.java:211)
at com.infoengine.procunit.adapter.Adapter.send(Adapter.java:198)
at com.infoengine.SAK.ObjectWebject.invoke(ObjectWebject.java:262)
at com.infoengine.compiledTasks.file.D$3a$5cptc$5cWindchill_10$2e2$5cWindchill$5ctasks.wt.federation.queryprincipals$2exml.invoke(queryprincipals$2exml.java:100)
at com.infoengine.SAK.Task.invoke(Task.java:1806)
As per my understanding it shoud look for Administrator or wtadmin user but it is looking for some other user .. he is not present in WDS .. it is present in emnterprise AD.
Any suggestion would be helpful .on overcoming this issue ..
Message was edited by: Ryan Kelley
Enabling wt.org debug logging should give a better idea of why Windchill is looking for this user, and why Windchill is looking in the wrong LDAP. To enable the debug logging add the below line to your <Windchill>/codebase/WEB-INF/log4jMethodServer.properties file and restart Windchill:
log4j.logger.wt.org=DEBUG
