May 29, 2024 7:51 PM UTC
Multi-level CAD structure output to Excel
Version: Windchill 12.0
Use Case: I have an indented CAD structure. I can export this to Excel and the indentions will persist in a column as expected.
Description:
For use in another application however, I would like each indented level to be put into a new column to the right of the previous one. in the Excel export.
HelesicPetr
May 30, 2024 7:28 AM UTC
Hi @AJ_TROGLIO
Write an excel vba script to restructure the output from Windchill.
It is easier and you do not have to customize the Windchill
PetrH
Community Moderator
Jun 24, 2024 8:50 PM UTC
Hi @AJ_TROGLIO,
I wanted to follow up with you on your post to see if your question has been answered.
If so, please mark the appropriate reply as the Accepted Solution.
Of course, if you have more to share on your issue, please let the Community know so that we can continue to help you.
Anurag
avillanueva
23-Emerald II
Jun 25, 2024 3:04 PM UTC
Easy to do in excel with fill down formula that has a trim or clean function to remove the indentation.
