Apr 6, 2023 8:55 AM UTC
Multi Level Where Used Report
Hello Experts , Is there any way to generate " Multi Level Where Used Report" in windchill similar to "single Level Where Used Report" ?
avillanueva
23-Emerald II
Apr 6, 2023 12:19 PM UTC
Sorry if I am lost. The reports on the structure page are not where used reports. They go down not up. The Where Used tab and table are multilevel. Short answer is yes if you mean column differences. The only real difference between these reports would be how many levels you recurs up the structure.
mbabu10-MarbleAuthor
Apr 11, 2023 6:27 AM UTC
sorry for the confusion, i was referring below report.
HelesicPetr
Apr 11, 2023 7:33 AM UTC
Hello @mbabu,
No, there is not possible to create multilevel report in query builder (Report Management).
If you need multilevel report you need to crate own customization to achieve your needs.
I mentioned how to add attributes to a Where used table, but it is really not possible to add a usage attributes this way as a quantity.
There is another way how to customize the table but you need to know how to  create classes with code.
From my view I would create own function that shows own where used table.
PetrH
HelesicPetr
Apr 6, 2023 12:31 PM UTC
Hi @mbabu
The report does not exists OOTB.
As @avillanueva mentioned.
You can go to the Where used tab on WTpart or Related Objects on CAD model
You can export the table to several file types,
Then you can work with the output and get all the highest assemblies.
If you need to add some attributes to the table check following thread
https://community.ptc.com/t5/Windchill/How-to-Customize-where-used-panel-s/m-p/786728
PetrH
Apr 11, 2023 5:17 AM UTC
Thank you PetrH,  the shortcoming of about option is it wont capture the "qty " of item, Unlike Single level BOM report . that's why I was checking do we have any way to fetch multilevel BOM with QTY similar to single level BOM report . It was there in Windchill in past , but it got removed [ article -CS83061] . Thank you again for the helping hands!
Apr 11, 2023 6:11 AM UTC
is there any way to get "QTY" in multilevel BOM similar to single level BOM report?
