18-Opal
Oct 18, 2017 12:57 AM UTC
naming and numbering via OIR
Hi
i customized a epm document in product
so, creo makes a file that numbering like 'creo-000000032'
and file name get from number
i have 2 questions.
1. can i more customized about each type?
for example, creo make a part file that numbering like 'creo-part-0000032'
other case, if creo makes a drawing file, this file get number like 'creo-2d-0000033'
is it possible? if it is posiible , please give me a way
2. can i makes rule that library file read is possible, but download impossible?
when i get cad data from library
i can save in my local space as back-up file[formatted xxxx.prt.1]
it means team member didn't download libfile to team member's workspace
only read, or it can be used to create assemblies
thanks, good day
Oct 20, 2017 5:40 AM UTC
The reference link subtyping is just another possibility. The most important part to create subtypes for CAD-Documents is the xml file EPMDefaultSoftType.xml. There you need to define which CAD Type (CADASSEMBLY, CADDRAWING, CADCOMPONENT,...) is mapped to which type.
See also: http://support.ptc.com/help/windchill/wc110_hc/whc_en/Windchill_Help_Center/ProEWCIntegCustCADDocSoftType.html
Oct 18, 2017 1:34 PM UTC
I do not think you can do that as parts, assemblies and drawings all use the same OIR.
If you create yor own OIR for the various file types, if possible, then you could control it.
To get the number sequence, the OIRs would need to use the same sequence number in Oracle.
You must be able to download files in oorder to use them in an assembly. You can put rules in place that make all library content read-only to your users.
Oct 19, 2017 8:53 PM UTC
You can have multiple subtypes of an EPM Document. So you need a subtype for the model, the assembly and the drawing. Then you can have 3 different oir's to set a different number.
Search for the chapter "Soft Typing CAD Documents".
Oct 19, 2017 8:54 PM UTC
by the way, there is also an utility to switch the type to a sub-type for existing cad-documents.
