Dec 4, 2025 7:48 PM UTC
Need help hiding a CAD Document attribute based on context
Version: Windchill 13.0
Use Case: I need to hide the CAD Document attribute SAP_MATNO dynamically based on context in the windchill UI
Description:
Windchill Version: 13.0
Object Type: CAD Document
Internal Name: com.trw.ssc.DefaultEPMDocument
Attribute: SAP_MATNO (IBA)
Requirement
Expected behavior
  • When the CAD Document is created/edited/viewed inside the container named “Training”, the attribute SAP_MATNO should be visible in windchill ui.
  • In all other containers, the attribute must be hidden in windchill ui
Additional requirement
The logic must work consistently across:
  • View information page
What I’ve tried
I implemented an AttributeDataUtility class to check:
  • The attribute name
  • The CAD Document type (com.trw.ssc.DefaultEPMDocument)
  • The current container (resolved via NmCommandBean + TeamCCHelper)
Then the utility sets:
  • attrState.setVisible(false)
  • attrState.setReadOnly(true)
  • attrState.setValue(null)
However, I want to confirm:
  1. Whether this is the correct approach in Windchill 13.0, or
  2. Should I instead use UI Validation – Pre-Validation (Validator + service.properties.xconf mapping)?
Goal
Find the best supported method in Windchill 13.0 to hide a specific attribute for a specific CAD Document subtype based on current container name.
Looking for
  • Confirmation of the correct mechanism (DataUtility vs UI Validator) coding would be helpful
  • Example of a recommended implementation
  • Required XCONF registration steps
avillanueva
23-Emerald II
Dec 8, 2025 5:23 PM UTC
Just to confirm, your data utility method, do you have this working? Strange requirement. What the purpose of having this attribute only for Training context?
