Nov 12, 2025 4:27 AM UTC
Need help with PTC_ORGANIZATION_ID
I am using Windchill PDMLink Release 12.1 and Datecode with CPS 12.1.2.16
Is it Possible to change PTC_ORGANIZATION_ID (edit the attribute and change the organization value) for already checked in parts? found article but not able to add the attribute in table view for manual edit
https://www.ptc.com/en/support/article/CS432157
    Nov 12, 2025 6:22 AM UTC
    Article https://www.ptc.com/en/support/article/CS388883 needs the update with below note as its hidden by preference which is not mentioned in article
    • Note:The Set Org ID action only display when the preference Site>Utilities>Preference Management>Display> Expose Organization = Yes
    ref article:https://www.ptc.com/en/support/article/CS153744
    SA_1245588310-MarbleAuthorAnswer
