Jan 24, 2024 3:39 PM UTC
Need to edit publishing configuration in WIndchill
Hi All,
I have a subtype in "Document" . They are not eligible for publishing. They should not be sent to workers for Publishing
This is causing two problems :
1. It is keeping AutoCAD workers busy during their execution which delays the others publishing
2. Failed jobs count is high in WVS job monitoring
Can someone help me to let me know about how can we configure this
BR,
Prasanna
avillanueva
23-Emerald II
Jan 24, 2024 5:30 PM UTC
Can I assume that you do have publishers for AutoCAD files that you do want to publish? Are those EPMDocuments? And in this subtype of document, someone is loading an AutoCAD file?
Jan 25, 2024 12:13 AM UTC
Yes, we do have workers to publish. The requirement is that non native typed WT documents are not eligible so they should not be sent to workers for publishing. Only AutoCAD EPM Document types are eligible
They are currently being sent to AutoCAD worker for publishing
