Jan 1, 2021 5:14 PM UTC
need to propagate three properties from xconf
hello PTC. i would like to propagate the following properties from xconf to wt.properties.
wt.queue.executeQueues=false
wt.manager.monitor.services=MethodServer BackgroundMethodServer
wt.manager.monitor.start.MethodServer=1
Jan 2, 2021 6:56 PM UTC
Run xconfmanager with the -p command, propagate.
If you don't know this, are you qualified to be making this level of change to Windchill?
krthk86g1-VisitorAuthor
Jan 2, 2021 8:47 PM UTC
Hi BenLoosli,
Sure I am aware of the xconfmanager propagation. I would be grateful if I get to know the right tag in xconf to populate.
not able to position the right tag in xconf to populate to wt.properties.
Karthik
Jan 4, 2021 2:39 PM UTC
It would look something like this:
xconfmanager -s 'wt.queue.executeQueues=false' -t codebase/wt.properties
xconfmanager -s 'wt.manager.monitor.services=MethodServer BackgroundMethodServer' -t codebase/wt.properties
xconfmanager -s 'wt.manager.monitor.start.MethodServer=1' -t codebase/wt.properties
