Feb 20, 2025 4:22 PM UTC
Need to work on multiple Creo or projects simultaneously with windchill
I am using Windchill PDMLink Release 11.0 and Datecode with CPS M030
I need to work in multiple Creo or multiple projects with windchill, How it is possible
Here are the errors that I faced
While opening the second session first session is automatically closing
    avillanueva
    23-Emerald II
    Feb 20, 2025 5:00 PM UTC
    Check out this article which might be similar to your post. If you can expand a bit on your situation, that would be great.
    https://www.ptc.com/en/support/article/CS202061
    Are you using multiple servers or just need to run multiple workspaces at the same time in different Creo sessions on the same machine?
    Community Moderator
    Feb 26, 2025 7:25 PM UTC
    Hi @bbalan,
    Anurag
