May 19, 2015 2:31 PM UTC
New Change Notice
New Change Notice on a CAD part file gives me the following error: You do not have create permission for this object.
Checking the Method Server log, I see: No Lifecycle template could be found for the wt.change2.WTChangeOrder2
I have gone back through the OIRs and the Team settings to be sure they have the proer roles.
Where else do I need to look to resolve this issue?
It does not give me this error on the development system using the OOTB OIR/Workflow, etc.
The OIR and Workflow on the production side are copies of the OOTB ones and then some modifications, mostly in the OIR to the names of the Lifecycle, Team and folder location.
tstacyAnswer
2-Explorer
May 19, 2015 2:37 PM UTC
Have you double-checked the spelling of the lifecycle name in both the OIR and in the lifecycle administrator? Also, make sure the Lifecycle is checked in. Those are the issues we've run into with this error.
tstacy2-ExplorerAnswer
2-Explorer
BenLoosli23-Emerald IIIAuthor
May 19, 2015 7:56 PM UTC
The person who did the copies from the OOTB names used 2 different naming schemes and didn't go back and update everything. I thought I had checked them all but I missed this one. It does work now.
