Jan 29, 2026 4:00 PM UTC
New Downstream Part with different Manufacturing Views
Version: Windchill 12.1
Use Case: Hi, we have got this situation: - "12345" Part Number ( Design) -> New Downstream Part "12345_100" (Manufacturing Plant 1)
Description:
Now we should create
-> New Downstream Part "12345_100" (Manufacturing Plant 2)
If I try to create, Windchill tell me that PartNumber already exist,
How can we do?
Any idea?
Best regards
Gianpaolo
shussainiAnswer
Feb 4, 2026 4:23 PM UTC
This is very much possible. First , You will have to restructure your View Hierarchy as below.
Then transform your Design BOM to Mfg using the New Downstream part action as mentioned by you. This will be your Master or Plant Neutral BOM. From manufacturing you can then transform to Plant1, 2 and so on using the New Downstream Branch action instead of new downstream part. This way you will have the same number for the part to be used in multiple plants and subsequent push to ERP.
I would recommend you do a thorough testing with this setup. NOTE that the view hierarchy changes will NOT be possible once transformations are carried out based on a particularly view hierarchy. So plan the View hierarchy upfront. Spend as much time possible to brainstorm with multiple stakeholders before finalizing anything putting in Production.
Hope this helps.
Regards
~Syed
Fadel
23-Emerald II
Jan 29, 2026 4:43 PM UTC
refer to below demo (basically cerate a new view version of  Mbom  and then create EQL manually )
Buiꓘa
Jan 29, 2026 4:58 PM UTC
Hi Fede,
really thanks for your quick reply.
But Windchill 12.1 seems not to have such an action.
Maybe is there an option to activate?
Below the Manufacturing Action Page.
Best regards
Gianpaolo
18-Opal
Jan 29, 2026 5:01 PM UTC
Hi @GianpaoloGallo,
Are you logged in as an Administrator?
If not, you will need to be granted the new view version access through ACLs.
