22-Sapphire I
Feb 2, 2017 11:27 PM UTC
New qml report - find latest at one of listed states
I was asked to provide a report of the latest version of all drawings at either Released or Prototype Released.
Search allows you to do this because the logic applied is:
- (Filter out anything by state / context that you don't have READ access to)
- Filter out non-latest iteration each Revision (hard-coded in search)
- Use any State criteria; filter out any not any those state(s)
- Depending on preference, return latest of what remains or all (default - latest)
For this data you get B.2 Released as required - essentially search allows you to apply a config spec including state to CAD Doc's (or other)
A.1 In Work
A.2 Prototype Released
B.1 In Work
B.2 Released
C.1 In Work
But, Creating a query builder report to apply the logic in this same sequence turned out to be tricky.  By default the qml logic is:
- Filter out non-latest iteration each Revision (direct criteria)
- Find latest using standard sub select on branch id
- Then, apply any State criteria
If you filter out for example In Work, it returns nothing for the data above.
Kudos to tech support engr Jaysel Meledath at PTC who kept with this and figured it out using the appropriate sub select.  Seems like it might be helpful to others - leaving it to PTC to make available.
ocorten-2Answer
Nov 21, 2022 11:13 AM UTC
Got it working by adding an extra criteria for State = RELEASED in the sub-select for the maximum Version Sort id
Apr 23, 2018 6:27 PM UTC
Can you share the QML of this report?  Or screen shots?
MarcoTosin
Apr 24, 2018 6:19 AM UTC
You can find lots of report ready to use in this document https://community.ptc.com/t5/Windchill-Questions/Resource-for-reporting/td-p/448738
Marco
Apr 24, 2018 12:54 PM UTC
Except I'm still not finding what I'm looking for.  I need to report that Latest Released Revision of a WTPart.  There may be multiple Revisions of this part that are Released and the Latest Revision, regardless of State, may be In Work.  For example:
PART12345  Rev. A.1  Released
PART12345  Rev. B.1  Released
PART12345  Rev. C.1  In Work
I want the report to send back the Latest Released Revision, which in this case is Only PART12345 Rev. B.1
The QML examples I tested came back with Blank results because the Latest, PART12345  Rev. C.1, is NOT Released.
Nov 21, 2022 10:48 AM UTC
Hi Mike,
I am running into this same issue.
Reading the final lines it looks like Tech Support (Jaysel Meledath) supplied you with the correct sub-select to get this done.
Can you share it here as well?
ocorten-212-AmethystAnswer
Jun 19, 2025 7:16 AM UTC
Hello ,
I applied the same query , i get result as expected.
but..
for few data the result is not expected its giving me the WIP data  as the latest one , it should give previous released data.
any help on this issue will be appreciated.
Nimish
