TomU
Aug 22, 2016 3:53 PM UTC
New Servers Not Showing Up
Is anyone else having issues with new servers not showing up on the Windchill Performance Advisor site?  I have several servers that have been sending data from almost a month now that still haven't appeared.  I opened a case with PTC but it's been almost two weeks with no solution.   Curious if this is happening to anyone else.
8-Gravel
Aug 24, 2016 1:16 PM UTC
Hi Tom,
Are these 11.0 servers recently updated to M010 ?
If so, there's a known issue for servers updated from F000 to M010.
See https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS243544
Cheers,
Matt
TomU
TomU23-Emerald IVAuthor
Aug 24, 2016 2:08 PM UTC
No, these are both 11.0 systems installed directly at M010 w/CPS01.  I turned on WA logging last night and can confirm data is definitely being uploaded to PTC.  I'm questioning whether the upload URL is correct.  I'm waiting to see what support says.
wt.jmx.core.transport.SimpleHttpTransport Administrator - wt.jmx.core.transport.SimpleHttpTransport Base URL=https://appstest.ptc.com/qualityagent
com.ptc.wa.send.WAReportSendManager Administrator - Report was successfully sent on attempt number 1 and took 2.625 seconds
8-Gravel
Aug 24, 2016 2:25 PM UTC
Hi Tom,
That looks like its uploading to one of the test systems.
Its should be https://apps.ptc.com/qualityagent
Can you check the value of wt.jmx.core.transport.SimpleHttpTransport.instance.QUALITYAGENTSIMPLEHTTP.targetURL in wt.properties ?
Cheers,
Matt
