New subtypes that i have created in the Type and Attribute Manager are not visible in the Folder contents
Hi
I have created subtypes of the Document in the Type and Attribute Manager and accordingly created new OIR as there is different team template for these dcoument types.Now when i am selecting the view in the Folder content as "All" ;the documents of the newly created doctypes are not visible.I can only see the new doctype documents when i select the view as the "Documents" or "Contents" or"Last Modified".
Do we have to register the new subtypes in any propery file?
Any help will be highly appreciated!
Thanks in advance
Regards
Samresh
Samresh
Did you try editing the "ALL" table display setting. I had experiences in the past with this. The "ALL" view actually filtered out some types, and I had to edit the view as admin..
http://support.ptc.com/cs/help/windchill_hc/wc101_hc/index.jspx?id=UserSetupTableViewNew&action=show
Darren
Darrens suggestion is likely the issue you are seeing. There should not be any registering required.
Jarrett
Thanks Jarrett for your reply.
Kindly refer to my reply to Darren and let me know if you give some valuable inputs on this one.
Regards
Samresh
