Feb 3, 2025 7:43 PM UTC
No Action options after Check Out of wtPart
Version: Windchill 12.0
Use Case: When selecting Check Out on a wtPart the object is checked out to the user. There are no actions available after check out.
Description:
If they use Check Out and Edit then they have normal actions.
It seems that the current version/view is "working copy" if they select Info in the history table for the "Original version" then menu options are available again.
Mar 11, 2025 5:38 PM UTC
the ReassignViewsFilter filter is using the existing isInRole method in the ValidationHelper class
looks like there is a class cast exception thrown in our custom ReassignViewsFilter class
HelesicPetr
Feb 4, 2025 12:54 PM UTC
Hi @LG_10096154
I would recommend to restart the Windchill server with a temp cleanup
PetrH
Community Moderator
Mar 11, 2025 5:25 PM UTC
Hi @LG_10096154,
Anurag
LG_1009615414-AlexandriteAuthorAnswer
