Jun 14, 2011 2:57 PM UTC
"No Cache designated vault" exception while uploading graphics
I'm using Windchill ProjectLInk 9.1, trying out the Structured Authoring test cases.
When trying to load a graphic file into the workspace "Tech_Pub", after selecting the file and
clicking finish, the UI goes to a page with a "Processing..." gif animation and never returns.
I checked the MethodServer log file (MethodServerLog4j-7344.log), and it has an exception:
2011-06-14 10:16:56,090 ERROR [RMI TCP Connection(26)-10.0.0.82] wt.fv.uploadtocache -
(wt.fv.uploadtocache.uploadtocacheResource/10) wt.util.WTException: There is no Cache designated vault or active folder for Cache designated vault on Local Master Site.
Does anyone know what this means and how to fix it?
Richard Steadman
Jun 14, 2011 3:11 PM UTC
Richard, try this:
1. Go to Site>Utilities>External Storage Administrator>Vault Configuration.
2. Click each folder/vault/host in the right area, then click Mounts>Validate, confirm no error message.
Make sure there is no Read-only vaults/folders and all the vaults/folders are enabled
Richard, try this:
Jun 14, 2011 3:31 PM UTC
Thanks for the quick reply Dmitry,
In the Hosts section, the defaultuploadfolder did not validate. So I unmounted it and made
a new one in a new folder on the file system, and then it did validate.
I was able to load the image into the workspace.
Thanks very much
Jun 21, 2022 9:20 AM UTC
In addition to the accepted solution you can also visit:
