Jun 25, 2014 6:46 PM UTC
Noobie question on formats
I've been using Pro/Engineer for 562 years, but Windchill is new to me.... still have trouble not thinking like folders and subfolders.
I create a new part and drawing offline, i.e., on my hard drive or on the company server. The drawing has a format with title block, etc. We have this format on the company server (i.e. a drive letter), but the definitive version with the same name is on Windchill. If, when the part and drawing is complete, I check them in to Windchill, what happens to the format file? Does it load up as well? I don't want that to happen. What I want is, next session that I open that drawing (from Windchill) I want the format to come from Windchill, not from the drive.
2-Explorer
Jun 25, 2014 8:32 PM UTC
If it is configured right ...
When you open the drawing in a session connected to Windchill it should get the format from Windchill and ignore the format that is there on the drive. The reason it should do that is that the drawing has the format name in it and the first place it should look for that name is the local Workspace, then Commonspace, and if not found, then the current directory.
If you first opened the format .frm file and saved it to your workspace, Windchill would show a name conflict and would not allow you to check it in because it wasn't checked out. You could Add the Windchill version, which would overwrite the local version, and, not being new anymore, would also not check in.
Finally, the Admin for Windchill should have set the permissions on formats so that no one can change them without an authorized effort.
It's a great question. Maybe the Cliffs Notes guys could work on a guide.
Jun 25, 2014 9:04 PM UTC
Thanks, that helps a lot. But if I have a config.pro setting that specifies a location for formats like so:
pro_format_dir X:\Creo_Config_Files\Formats
...will my ProE session still look for the format in the Workspace/Commonspace hierachy first?
I know I could specify my formats location on Windchill like so:
pro_format_dir wtpub://Windchill/Libraries/Library/Formats
... but we are not always on Windchill. I know that in theory we should be, but sometimes we do stuff in development with umpteen variations that we try out, etc, you know, and we don't want to mess with it at the time.
Jun 25, 2014 10:36 PM UTC
The best advice I could give you is to get used to working in Windchill... always. You can still access your Workspace if working offline and you get the benefit of leveraging existing content (think nuts, bolts washers etc.). Plus when one of the what-if scenarios inevitably grows legs it will be much easier to make it "real" because it's already in Windchill and you won't need to spend (read waste) time resolving conflicts or creating duplicates.
You can pretty much do whatever in the Workspace and it's the Check In that pushes new or modified content into Windchill. You can Upload which will push content to the Server side of your Workspace and potentially get the benefit of backups, but without pushing your "what-if's" to the Server.
My recommendation would be to set your config.pro to map to Windchill located formats, start templates, custom symbols etc.
If you're dead set on working in Folders, then you can do a replace the format with Page Setup and navigate to the Windchill location for the "real" format. Much, much more to it when it comes to models so use caution and be methodical. I suspect that if you go through it once you'll recognize that it's easier to run your what-ifs in Workspace and back them up to disk if/as you need to store them.
Jun 27, 2014 1:33 PM UTC
There is a config.pro setting for the server.
dm_remember_server and the default is yes.
Formats are pulled from the Windchill library.
Templates and start parts are pulled from a disk on the server.
Drawing templates pull the format with them from Windchill.
When I revise a format, I save the new file in Windchill and a backup copy to disk.
Windchill will look in your local workspace first, then the server for your formats when loading a drawing.
When creating a drawing, you browse to the format_dir and select a format. However, Pro/E loads the format by name and will pull the format from your workspace before requesting it from the server. This can be critical if you make changes to your formats. We changed the company address and it took about a year before we had to stop rejecting drawings for having the out-dated address.
Jul 2, 2014 2:06 PM UTC
I didn't know that config.pro option.
So in other words you have config.pro options that point to all these places in their different locations?
As an example, you might have the following in your config.pro:
start_model_dir Z:\Creo_Config_Files\Config_Files
template_solidpart Z:\Creo_Config_Files\Config_Files\inlbs_part_solid.prt
template_designasm Z:\Creo_Config_Files\Config_Files\in_lbs_assembly_solid.asm
template_drawing Z:\Creo_Config_Files\Config_Files\c_drawing.drw
... and maybe symbols on Windchill as well, e.g.:
pro_palette_dir wtpub://Windchill/Libraries/Library/Symbols
symbol_instance_palette_file wtpub://Windchill/Libraries/Library/Symbols/standard_notes.drw
I like the way this sounds. It's imperative the format be locked down: the start part and drawing templates; not so much.
Ugh. We wanted to make the format and its folder read-only on Windchill, so that it coudn't be changed. But I guess if it's in your workspace it can be changed. Does it get checked out like a part or drawing file?
Jul 2, 2014 2:21 PM UTC
Change the State of the Formats to lock them down. If a User inadvertently modifies one in the Workspace (you should look at your Formats if this is happening) they would not be able to Check In. If there is a modification occurring the User would not be able to Check Out a "Released" Format buy could use Continue to make a modification. Check your Access Policy for permissions at each State in the CAD Document Lifecycle but if OOTB Released is probably not editable by general User.
