11-Garnet
Jun 6, 2023 4:45 AM UTC
Not able to download an export importable spreadsheet for for multiple object.
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.0.0
In the past user will able to download an export importable spreadsheet on folder or container level. This is no longer possible.
as we checked this option is available for single object only but not possible for multiple object.
    Fadel
    23-Emerald II
    Jun 7, 2023 7:28 AM UTC
    Hi , I just tested on  12.1 , the action is available :
    make sure that you select only objects eligible to be exported .
    you may also enable jcaDebug to see if action is available and just hidden .
    Buiꓘa
