3-Newcomer
Nov 13, 2023 11:59 AM UTC
Not able to send Subscription mail for 3000+ users at a time on Document Management.
We are not able to sent <subscription mail> for 3000+ users at a time.
Can someone please help here?
avillanueva
23-Emerald II
Nov 13, 2023 2:53 PM UTC
Is there an error or screen shot you can send? What is the use case of sending email to such a large group?
3-Newcomer
Nov 14, 2023 1:55 PM UTC
Hi Avil,
Thank you for your response.
We don't have any error screen shot.
Here the issue is when we added a group containing 3000+ users  in the To list of subscription, it is only sending mail to 1200 users but not to 3000+ users.
Kindly let me know if you require any further details.
avillanueva
23-Emerald II
Nov 14, 2023 2:09 PM UTC
Test test this, watch the email or notification queue. If you see one entry created when it sends a mail, that suggests the restriction is in your email server or forwarder. If its PDMLink, you would see 3000 emails  generated and it actually showing only 1200 email jobs created showing that it hit a limit. I suspect that somewhere along the way, when it expands the to field, we are exceeding some field maximum but I also think that this issue is external to PDMLink.
Fadel
23-Emerald II
Nov 14, 2023 9:52 PM UTC
Hi would try after setting property wt.mail.maxRecipients  to 3000+ , and a restart  :
  • xconfmanager -s wt.mail.maxRecipients=<maximum number of recipients> -t codebase\wt.properties -p
Its also worth to check smtpd_recipient_limit if you are using postfix as SMTP server
Buiꓘa
3-Newcomer
Nov 16, 2023 4:35 PM UTC
Hello Fadel,
I have tried the above step but still the issue exists.
Fadel
23-Emerald II
Nov 16, 2023 7:38 PM UTC
There is no other setting from windchill side, you should investigate limitations from your SMTP Relay/Gateway , did you discussed this with your IT ?
Buiꓘa
