May 12, 2023 6:33 PM UTC
Not sure how to add parts per million as a unit
I am using Windchill PartsLink Release 12.1 and Datecode with CPS 12.1.2.0
How do you register ppm (Parts per million) as a valid unit in Windchill? It doesn't seem like there are any concentration units to base it on. I'm not a unit expert so I'm probably missing something obvious.
    joe_morton
    May 15, 2023 5:53 PM UTC
    Create the new quantity of measure per: https://support.ptc.com/help/wnc/r12.1.1.0/en/index.html#page/Windchill_Help_Center/typeattr/TypeMgrQuantOfMeasCreate.html
    Parts per million is unitless, so you'd leave the units field blank.
    joe_morton
    May 15, 2023 6:00 PM UTC
    In older versions where enumerated customization is not in type and attribute management, you'll need to use enumCustomize. See support article:
    https://www.ptc.com/en/support/article/CS32653
