Number Value With Space
In the Legacy System,the value for the Number contains the 'SPACE"
Ex:1111 TEST 777777777 KKKKK
Customer demanding the same format should be followed for the WTObject Numbering system.
How to create the WTObjects with "Space"
Regards
Gangadharan.N
Hello Gangs,
You can check the init rule.Say for ex. for generating NUMBER SEQUENCE we use a java class that refers the generating sequence.
So in case if you want your own Numbering Pattern you can ovveride it with your own customised class.
Sriram
