Sep 4, 2024 11:30 AM UTC
NX and WGM "freezing" after undock/redock
Version: Windchill 12.1
Use Case: User undocks laptop while running NX and WGM for meeting, then redocks and NX/WGM is frozen and needs to be restarted
Description:
NX 2206 and WGM 12.1
From the user, "Still having an issue when most times when i dock/un-dock for meetings i come back and my NX model is frozen. It allows me to switch between part windows but cant rotate or zoom or use any tools. Requires a WGM/NX reboot to fix."
We just moved this group to using Windchill a few months ago, and the issue was never reported prior, so I suspect WGM may be trying to do something during the un-docked period, that is causing the lockup?  Meetings are all within the building, so the user would be going from a plugged in ethernet cable, to wifi, and back.
This may, or may not be related to the random freezing, when WGM decides to do 'something', and renders NX totally non-responsive for some period (a few seconds to half an hour or more).  This sounds similar to the issue another reported on here, using Catia.
Catalina
Community Manager
Sep 9, 2024 3:11 PM UTC
Hi @Dave_K,
Thank you for your question!
Thanks for using the Community!
Best regards,
Catalina
PTC Community Moderator
Catalina | PTC Community Manager
