NX Publishing rule + Additional type convertion
  • June 9, 2025
  • 4 replies
  • 439 views
Hi Everyone,
I need an NX publishing rule, if anybody has kindly share.
Check-IN
PDF & STEP file conversion.
AJ
avillanueva
23-Emerald II
June 9, 2025
https://www.ptc.com/en/support/article/CS111916?source=search
All you need to do is change the authoring application to UG and tailor any additional rules you need.
Community Moderator
June 13, 2025
Hello @Amirtharaj_K,
It looks like you have a response from our community champion. If it helped you solve your question, please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
@avillanueva Thanks for the reply.
In NX, all file types use the .prt extension, unlike Creo, which uses separate extensions such as .asm, .prt, and .drw for assemblies, parts, and drawings.
Because of this, how can we apply automatic conversion rules in NX?
Could you please share some tips or guidance on how to handle this?
Aj
avillanueva
23-Emerald II
August 4, 2025
I am familiar with that. I am assuming you have separate .prt files that represent just drawings separate from normal 3D geometry? How were they configured via the WGM? The CAD Documents might have been tagged differently to appear as a drawing vs CAD Part in that case.
