Jan 12, 2015 8:56 AM UTC
Object Initialization Rules
I create a document subtype named "DocsRef" What I'm trying to do is when you create a document under "DocsRef" The default folder shoul be "DOCUMENTS"
I create OIR and this is my code.
<AttributeValues objType="wt.doc.WTDocument">
<AttrValue
id="folder.id"
algorithm="com.ptc.core.foundation.folder.server.impl.FolderPathAttributeAlgorithm"
ignore="false"
force="false"
final="false">
<Arg>/wchill://Windchill/Product/Projects/Documents/</Arg>
</AttrValue>
</AttributeValues>
After that I create new rules and named it DocsRef and I choose DocsRef type and upload the xml file with the code above.
When I try to create new document under DocsRef type. I received this error.
can somebody tell me what is the cause of the error?
Thanks!
Luar
mraneAnswer
Jan 12, 2015 9:15 AM UTC
Hi Luar,
The exception clearly states that the folder does not exist. Note the folder needs to exist before you create the document and expect to save it in the folder. Consider the OIR entry as shown below :
'Default' needs to exist and the folder ABC is the folder in which I need to store the documents. It is the first level folder.
<AttrValue id="folder.id" algorithm="com.ptc.core.foundation.folder.server.impl.FolderPathAttributeAlgorithm">
<Arg>/Default/ABC</Arg>
</AttrValue>
-Malavika
mrane1-VisitorAnswer
Hi Luar,
</AttrValue>
-Malavika
Luar1-VisitorAuthor
Jan 12, 2015 9:32 AM UTC
Hi Malavika,
Thankyou for prompt response. The error is gone but what I want to do is the path in Select Folder should be the folder path where I want my file to store. Or can I set the radio button default on Auto select Folder?
Luar
Jan 12, 2015 9:50 AM UTC
In the OIR file, you would already have the <AttrConstraint id="folder.id".....
Replace it with the following snippet:
<AttrConstraint id="folder.id" algorithm="com.ptc.core.rule.server.impl.GatherAttributeConstraints">
<Value algorithm="com.ptc.core.rule.server.impl.GetServerPreGeneratedValue"/>
<Value algorithm="com.ptc.core.rule.server.impl.GetImmutableConstraint"/>
</AttrConstraint>
-Malavika
