Feb 25, 2022 3:15 PM UTC
Object Reference Attribute displays (Unassignable) instead of an user picker
I am using Windchill PDMLink Release 11.1 and Datecode with CPS M020-CPS11
I was following this guide https://www.ptc.com/en/support/article/CS216763 to create a user picker with a local object reference attribute.
First I added a column via AddColumns utility.
Then I created a new subtype of wt.doc.WTDocument called Fabians_Document.
Inside this subtype I created a local attribute of type Object Reference called Co-Author.
The attribute was set up like this:
Other side attribute: name
Other side class: wt.org.WTUser
Now, when I create a new document of this subtype the attribute Co-Author just says: (Unassignable)
However, I expected to have a user picker there.
    18-Opal
    Feb 28, 2022 8:39 AM UTC
    Hello Fabian Schmidberger,
    I'm Charles from PTC Technical Support in Europe, I will be assisting you with your question opened for Arsandis.
    Can you provide corresponding log files via email to cgautier@ptc.com?
    Please reproduce the use-case with the error message, then send me the MethodServer log and pinpoint the timestamp and the login used.
    Kind Regards,
    Charles Gautier.
    7-Bedrock
    Mar 11, 2022 3:44 PM UTC
    Hello Charles Gautier,
    We also facing similar issue, is there any work around/solution for this issue? If yes, can you please share the related article.
    Kind Regards,
    Vikram Prabakaran
    Mar 16, 2022 9:42 AM UTC
    I'm facing the same issue, however to get a user picker you can create an IBA / global attribute or local attribute on the document and follow this article
    https://www.ptc.com/en/support/article/cs230207
    Best Regards,
    Ulla Harneit
