Jul 31, 2024 2:59 PM UTC
OCI autonomous serverless DB compatibility with PDM v12
I am using Windchill PDMLink Release 12.1 and Datecode with CPS 12.1.2.0
Hello
We would like to know if OCI (Oracle Call Interface) autonomous serverless DataBase is compatible with PDM v12.1.
we face some issues like creating unstructured index xml (Oracle fatal error)
Best regards
Here are the errors that I faced
Oracle fatal error: unstructured index xml
Aug 1, 2024 11:44 AM UTC
You are encountering issues with creating unstructured XML indexes in your OCI (Oracle Call Interface) autonomous serverless database while using PDM v12.1. Here are some insights and potential solutions:
Compatibility:
OCI Autonomous Serverless Database: Generally, OCI autonomous databases are designed to be highly compatible with various applications and use cases. However, specific compatibility with PDM v12.1 might require certain configurations or updates.
Error: Oracle Fatal Error - Unstructured Index XML
Unstructured XML Indexes: Oracle has deprecated unstructured XML indexes in favor of XML search indexes in newer versions2. This might be causing the issues you’re facing.
Solution: Oracle recommends recreating unstructured XML indexes as XML search indexes. This can improve compatibility and performance2.
Steps to Resolve:
Update Indexing Approach:
Transition from unstructured XML indexes to XML search indexes. This involves updating your indexing strategy to align with Oracle’s current recommendations.
Check Documentation:
Refer to the Oracle Help Center for detailed guidance on creating and managing XML search indexes
I hope this info helpful to you.
Aug 1, 2024 4:48 PM UTC
Does the PTC support matrix mention this version of Oracle?  If not, then you do not get PTC support.
