Oct 10, 2023 6:34 AM UTC
OData custom mapping f. ClassifiedObjects problem
I created a custom ClassifiedObjects.json configuration for the ClfStructure domain so as to return more properties than the defaults provided by Windchill.
REST / OData Version we are using: windchill 2.2.2 REST Services
NOTE: we are talking about this type of query, for instance
GET [host]/Windchill/servlet/odata/v3/ClfStructure/ClfNodes('CT11101010')/ClassifiedObjects?$count=true
All is fine except for the mapping of an internal field whose internal Windchill type is:
com.ptc.core.meta.common.FloatingPoint
Since we are dealing with a "Real Number" (as stated in the Windchill GUI) I expect this to be mapped as a "Double" or "Single" like so:
"name":"StockQty",
"internalName":"INVENTORY_ARTICLE_STOCK,
"type":"Double"
However, using both Double or Single datatypes will yield the following server response:
"error": {
"code": null,
"message": "The value '(Unassignable)' is not valid for property 'StockQty'."
Mapping the property as a "String" will yield the value "(Unassignable)" in the response.
Hence my question: which datatype should be used for mapping FloatingPoint values in OData?
Or is this a bug?
Best regards
Fadel
23-Emerald II
Jun 27, 2025 1:02 PM UTC
Take a look at :  https://www.ptc.com/en/support/article/CS409515
It should be Double , looks like an issu e
Real Number com.ptc.core.meta.common.FloatingPoint Double
Buiꓘa
