Mar 8, 2023 12:32 PM UTC
odata function to get distribution target publishing and transaction status
Hi all,
I have te requirement to get the status (no/sucess/failure) of a specific distribution target by calling a odata service.
There can be more then one.
Does anyone know, how to get the highlighted values above by using odata?
Jürgen
HelesicPetr
Mar 8, 2023 2:38 PM UTC
Hi @JD_8606834
The help center can be useful. use a RestAPI
GET Windchill/servlet/odata/ESI/DistributionTargets
DistributionTargetsAssoWithContext
Hope this can help
PetrH
Mar 8, 2023 2:54 PM UTC
Hi PetrH,
thanks for your reply.
if I understand it correctly, the functions that you are mentioning are kind of general functions, not in the context of a part.
I need a service, to which I can pass a part id/number and it will return the status of the transaction for exactly that particular part.
All the part related odata services that I tried do return a lot of attributes but not the status of the transactions related to every assigned distribution target.
Jürgen
HelesicPetr
Mar 9, 2023 9:10 AM UTC
Hi @JD_8606834
If you have gone through others sections in the help you would find this>
example_esi_retrieve_DistributionTargetsAssoWithWCObjects
Hope this can help.
PetrH
