Oct 2, 2022 12:21 PM UTC
odata reporting domain
Hi Team
Does ODATA Reporting Domain work for you? I get 500 on all tests.
curl -X 'GET' \
'https://DOMAIN.com:443/Windchill/servlet/odata/v1/Reporting/OpenChangeNoticess?%24count=false' \
-H 'accept: application/json'
java.lang.NullPointerException
at com.ptc.odata.core.entity.processor.ProviderProcessor.readEntityCollection(ProviderProcessor.java:254)
at com.ptc.odata.core.entity.processor.EntityProviderProcessor.readEntityCollection(EntityProviderProcessor.java:114)
at com.ptc.odata.windchill.entity.service.WcEntityProviderProcessor.readEntityCollection(WcEntityProviderProcessor.java:290)
at org.apache.olingo.server.core.ODataDispatcher.handleEntityCollectionDispatching(ODataDispatcher.java:529)
at org.apache.olingo.server.core.ODataDispatcher.handleEntityDispatching(ODataDispatcher.java:511)
at org.apache.olingo.server.core.ODataDispatcher.handleResourceDispatching(ODataDispatcher.java:152)
at org.apache.olingo.server.core.ODataDispatcher.dispatch(ODataDispatcher.java:118)
at org.apache.olingo.server.core.ODataHandlerImpl.processInternal(ODataHandlerImpl.java:164)
at org.apache.olingo.server.core.ODataHandlerImpl.process(ODataHandlerImpl.java:85)
at org.apache.olingo.server.core.ODataHttpHandlerImpl.process(ODataHttpHandlerImpl.java:74)
at org.apache.olingo.server.core.LocalODataHttpHandlerImpl.process(LocalODataHttpHandlerImpl.java:31)
at org.apache.olingo.server.core.ODataHttpHandlerImpl.process(ODataHttpHandlerImpl.java:88)
at com.ptc.odata.windchill.entity.service.RetryableRequestMediator.process(RetryableRequestMediator.java:476)
at com.ptc.odata.windchill.servlet.WcRestServlet.service(WcRestServlet.java:200)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:764)
WC 12.0.2
Am I doing something wrong?
cheers -- Rick
HelesicPetr
Nov 8, 2023 10:21 AM UTC
Hi @rleir
It's a pity if you don't have time to contact PTC.
If you don't do that no one will do it for you and the issue will never be solved..
PetrH
rleir17-PeridotAuthor
Oct 2, 2022 12:39 PM UTC
Maybe this article is a clue to the answer?
WRS Reporting Domain does not apply Java Method on WRS 2.3
https://www.ptc.com/en/support/article/CS366253
HelesicPetr
Oct 3, 2022 6:18 AM UTC
Hi @rleir
What Windchill version do you use?
In Windchill 12.0.2.2 I can't find Reporting Domain.
PetrH
Oct 3, 2022 6:07 PM UTC
Hi Petr
Do you have CPS-7?  I think the Reporting Domain appeared then.
See it discussed in WRS 2.3 on page 188.
https://www.ptc.com/support/-/media/support/refdocs/Windchill_REST_Services/2,-d-,3/wrs.pdf?sc_lang=en
cheers -- Rick
HelesicPetr
Oct 4, 2022 7:10 AM UTC
Hi @rleir
In my case the API does not work.
Can not load the RestApi page for the PTCReportingDomain
Error in a browser
Errors in a MS Log
2022-10-04 09:08:58,451 ERROR [ajp-nio-127.0.0.1-8010-exec-5] com.ptc.windchill.enterprise.queryBuilder.QueryBuilderUtil admin - cvc-complex-type.2.4.b: The content of element 'operand' is not complete. One of '{column, constant, keyword, function, reportAttributeReference, subQuery, reportViewAttribute}' is expected.
2022-10-04 09:08:58,451 ERROR [ajp-nio-127.0.0.1-8010-exec-5] com.ptc.windchill.enterprise.queryBuilder.QueryBuilderUtil admin - FATAL ERROR at Line Number: 116 Column Number: 35
2022-10-04 09:08:58,452 ERROR [ajp-nio-127.0.0.1-8010-exec-5] com.ptc.windchill.enterprise.reportBuilder.ReportBuilderDataManager admin - An error was encountered upgrading report template org.xml.sax.SAXParseException; lineNumber: 116; columnNumber: 35; cvc-complex-type.2.4.b: The content of element 'operand' is not complete. One of '{column, constant, keyword, function, reportAttributeReference, subQuery, reportViewAttribute}' is expected.
	at org.apache.xerces.util.ErrorHandlerWrapper.createSAXParseException(Unknown Source)
2022-10-04 09:04:03,212 INFO [ajp-nio-127.0.0.1-8010-exec-1] wt.system.err - java.lang.NullPointerException
2022-10-04 09:04:03,212 INFO [ajp-nio-127.0.0.1-8010-exec-1] wt.system.err - 	at com.ptc.odata.docs.ODataSwaggerContext.cacheMetadata(ODataSwaggerContext.java:213)
2022-10-04 09:04:03,212 INFO [ajp-nio-127.0.0.1-8010-exec-1] wt.system.err - 	at com.ptc.odata.docs.ODataSwaggerContext.getSchemas(ODataSwaggerContext.java:71)
2022-10-04 09:04:03,212 INFO [ajp-nio-127.0.0.1-8010-exec-1] wt.system.err - 	at com.ptc.odata.docs.ODataSwaggerPathBuilder.<init>(ODataSwaggerPathBuilder.java:65)
2022-10-04 09:04:03,212 INFO [ajp-nio-127.0.0.1-8010-exec-1] wt.system.err - 	at com.ptc.odata.docs.WcODataSwaggerBuilder.<init>(WcODataSwaggerBuilder.java:53)
I guess that there is some error in parsing and it could be a bug.
PetrH
Oct 6, 2022 12:42 PM UTC
Team
I have just been checking release notes for recent CPS versions, and found no mention of this problem or any fixes for it.
https://support.ptc.com/appserver/cs/update_advisor/update_advisor.jsp
https://www.ptc.com/en/support/article/CS273372
Is there another way to find which release fixes this issue?
Rick
HelesicPetr
Oct 6, 2022 12:49 PM UTC
Hi @rleir
Yes open a case to contact PTC support directly and ask them.
May be the issue has not been reported yet .
If Article does not exists it can not be in the CPS release notes.
PetrH
Nov 8, 2023 10:16 AM UTC
Agreed, Petr.  But I don't have time for PTC support cases, sorry! Maybe the moderators will take it upon themselves to pass a link to this thread over to whoever is responsible for QA.
cheers -- Rick
9-Granite
Jun 18, 2026 6:55 PM UTC
Hi ​@rleir , ​@HelesicPetr ,
I am getting the same issue for Windchill 13.0.2.10
by any chance did you get any finding on this?
Jun 25, 2026 4:50 PM UTC
why should he contact ptc when they take too long
