Aug 29, 2024 1:36 PM UTC
Odd NX assy navigator behavior with Windchill
Version: Windchill 12.0
Use Case: NX 2206 Users will open a large, top level assembly as "structure only", then expand 1 or 2 sub-assemblies, and the assembly navigator will jump to display a different sub-assembly, and NX becomes essentially useless.
Description:
User opens a large top level assembly, using "structure only" in NX.  Then the user will expand 1 or 2 sub-assemblies, and the Assembly Navigator will change to list a different sub-assembly, and the NX session becomes essentially useless.  You can click on things, but navigating the assemblies or parts, is non-functional.  Sometimes a fatal, or other error follows.
Top level assembly is just under 30gigs, and it is all in the local workspace.  Loading "structure only" should only be loading a minimal amount of data into the NX session.
Everything functions as you would expect, if you run an NX session disconnected from WGM.  I've done this by running a second NX session, which fails to connect to Windchill.  Then do the same load, and assembly expansion in both sessions at the same time.
Also, load time is about 10X faster, when not connected to WGM.
In this image, you can see that the NX session connected to WGM is showing one part number in the tab, but a different part number in the Assembly Navigator.  Compared to the stand alone NX session, which shows the matching tab and navigator column.  NX session connected to WGM also experienced a Fatal error.
We are looking for any insight on how to solve this issue, as it is limiting, and slowing our productivity.
Dobi
Aug 30, 2024 3:45 AM UTC
@Dave_K
The c0000005 error (when I had it popping up a few times 2 years ago) had to do with the registry being somehow corrupt. It was a difficult thing to reproduce but essentially boiled down to a stuck WFS service that had to be force uninstalled/removed with a Microsoft uninstall utility. I had a ticket with PTC on this and the recommendation was to:
- reinstall after the registry cleanup
- delete the %Appdata%/Local/Siemens folder
- run WGM as admin to first connect NX to it
- run per usual and hope for the best
Large assemblies will always run way slower in a stand-alone session than when connected to the WGM. Do you have any anti-virus software running? This may help: https://www.ptc.com/en/support/article/CS50545
We also have some other monitoring software that I had to exclude NX (ugraf.exe) and WGM (uwgm_client.exe) from to help the slow loads along. Our assemblies are in the 7GB range and with load_options.def file set to partially load + anti virus exclusions we got down to about 4-5 minutes instead of 15 without.
There is a known "feature" in WGM that will cause major slowdowns too that has to do with mass reporting. Do you have mass reported from NX (NX_Mass via MassPropMass and MassPropRollupMass) to Windchill with the MSP:Mass mapping PTC suggests? https://support.ptc.com/help/windchill/plus/r12.1.2.0/en/index.html#page/Windchill_Help_Center/WWGMforNX/WWGMNXAdminConfigMappingwithUnits.html# doesn't point out that if there are modeling errors in NX that NX happily resolves - they seem to trigger mass calculations on the Windchill side for the number of errors that exist. Specifically: if you have pk_topol errors showing up in your syslog, you can go from a 30second load/save to 15-20 minutes.
In NX if you do "Examine Geometry", "Feature replay" and "Part cleanup" it may help at least identify this. But there isn't a fix yet on Windchill not triggering a save even when you don't want one. The only thing I was able to do was remove the MSP:Mass mapping for NX_Mass until there's a fix in some newer version of WGM.
Dave_K12-AmethystAuthor
Aug 30, 2024 11:41 AM UTC
If it is corrupting the registry, I'd consider this issue to be much more serious, as it is involving more and more users.  It was one in late July, and at least 6 now.  The issue also comes and goes.  The first user with the issue changed his assembly load options from "partial lightweight" to "Partial loading" (still structure only), and the issue went away for almost 2 weeks, before returning.  But, if it is registry related, why does it only affect NX sessions connected to WGM?  Also, we don't always get the c0000005 error, sometimes it's "an invalid tag was passed to the tag module", or "memory access violation".  I think we always get a "failed to get column value for column DESCRIPTION" error though.
In our case the native NX session is MUCH faster loading than, than the session connected to WGM, I'm guessing that was a typo?  We do have anti-virus, and other monitoring tools in place, I'll dig deeper into that.  Yesterday I recorded an NX session connected to WGM, and a stand-alone, side by side, and performed the same functions.  Stand alone was done in a couple minutes, and the session with WGM took half an hour, then had the assembly navigator issue, which also renders the session useless.
OK, that "feature" could be part of it.  We do have mass reported from NX, and I have noticed NX performing saves, while opening parts, and we wondered why it was saving.  I haven't noticed any pk_topl errors, but I will keep an eye out.  Thanks for the anti-virus tips, I will pass them along to IT.
Dobi
Aug 30, 2024 2:35 PM UTC
Hi @Dave_K
After going through my notes last night I realized I confused my errors.
e0434352 - Registry issue with a stuck (or somehow not functioning) WFS. The PTC ticket I had on this essentially claimed that this was fixed in NX2206 and beyond versions of compatible WGM. So I apologize for that mix up there. I only had this occur on a NX1956 system upgrading to NX2007 lots of times (I'm the admin so lots of back and forth installs and uninstalls).
c0000005 - This came where a user was opening files from a workspace that wasn't sycned and updated. I did have to wipe the %appdata%/local/Siemens/NX2007 (that was our version) folder and it went away. It also went away in a clean workspace with freshly added latest files. I didn't feel like this was resolved to my liking - if at all - because I had no mechanism to reproduce the issue and figure out in more detail what was going on.
Siemens claimed that in the end it was most likely the issue was related to older versions of files in the workspace.
- part occurrence tree has been corrupted (possibly shadow part occ tree and real part occ tree are out of sync)
They suggested trying these environment variables:
SET UGII_SHADOWS_FIXUP=1
SET UGII_ENABLE_LINK_FIXUP=1
And then loading the assembly fully and saving.
In the other post you have on searching you say you have native-NX users... It may be the case where understanding how to properly sync and update workspaces when there are out of date flags is where you would at least want to start. It took a bit of time here to emphasize this practice and it still comes up often with the native-NX and previously TeamCenter users.
Yes, correct: a typo. Stand-alone NX will ALWAYS load way faster than a connected to WGM NX. This is because of the background syncs of meta-data and such. Anti-virus exclusions and there's also this: https://www.ptc.com/en/support/article/CS46526
Once all of that was in place, the only remaining item that was a showstopper was the pk_topol_eval error in NX. In my internal testing and without that error in place, the load time is 3-4x longer in WGM. If we're talking a few seconds natively, it's a few more seconds in WGM. If you're talking 2-3 minutes... it can very quickly become unusable.
The pk_topol_error was key, though in reducing any other time to as good as it can be. Depending on the complexity of the assemblies, it isn't hard to get.
Siemens recommended (in order);
  • Part cleanup (make sure everything is fully loaded and you select "work part and components". Select all checks except the "Serious Delete Actions" section)
  • Feature replay - this validates that features are properly linked together
  • Examine Geometry - to have a valid body, Data Structures, Consistency, Face to Face intersection and Self-intersection have to pass. If they don't, the user has to appropriately model geometries to make those issues go away. If you Select All here it'll highlight whatever isn't ideal
This is one of those items that PTC is treating as a bug because the pk_topol error will take seconds to resolve (per error) and you can have hundreds in a part ... so for an assembly it could take a long time to just open or save a file.
