Feb 12, 2024 9:02 PM UTC
OIR and burst configuration files not working
I am using Windchill PDMLink Release 11.1 and Datecode with CPS F000
We are not able to apply a burst configuration with an OIR file written to specification.
    HelesicPetr
    Feb 13, 2024 7:39 AM UTC
    Hi @ME_10767830
    It is good to share what you have done, how the OIR looks like, and what is your burst configuration.
    How can someone know what you have done wrong.
    PetrH
    Feb 13, 2024 5:13 PM UTC
    Sure, please tell me what you notice.
    (OIR) dynamicdocument.xml
    <AttributeValues objType="com.SAMPLE.DynamicDocument">
    <!-- set the number to a generated number -->
    <AttrValue id="number"
    algorithm="com.ptc.windchill.enterprise.revisionControlled.server.impl.NumberGenerator">
    <Arg>{GEN:wt.enterprise.SequenceGenerator:EPM_seq:10:0}</Arg>
    </AttrValue>
    <!-- specify AttrConstraint tag -->
    <AttrConstraint id="number"
    algorithm="com.ptc.core.rule.server.impl.GatherAttributeConstraints">
    <Value
    algorithm="com.ptc.core.rule.server.impl.GetServerAssignedConstraint"/>
    <Value
    algorithm="com.ptc.core.rule.server.impl.GetImmutableConstraint"/>
    </AttrConstraint>
    </AttributeValues>
    atidefaults.bfc
    <?xml version="1.0" encoding="UTF-8"?>
    <!--Arbortext, Inc., 1988-2013, v.4002-->
    <!DOCTYPE createdefaults PUBLIC "-//Arbortext//DTD CreateDefaults 1.0//EN"
     "createdefaults/createdefaults.dtd">
    <!-- atidefaults.xml
    This file contains 'global' defaults for object creation
    parameters, i.e. these settings are applied independently
    of the DTD/Schema when no user-defined or DTD/Schema-specific
    setting is available.
    <!-- createdefaults
    NOTE:
    If the 'useroverride' attribute has a value of "on" then the
    user will be in full control of where new objects are located.
    All settings in this file or in a DTD/Schema-specific configuration
    file will be ignored in this case. Such settings are only honored
    if 'useroverride' is "off".
    For compatibility with earlier releases, the twowaymetadata feature is
    disabled by default. The feature must be enabled (twowaymetadata="on")
    for twowaymetadatarule elements in DTD/Schema-specific configuration
    files to work.
    <createdefaults maxnamelen="72" objectreuse="on" twowaymetadata="on"
    useroverride="on">
    <!-- dmsobjtype dmsgraphicobjtype
    A 'default' attribute value of the dmsobjtype or dmsgraphicobjtype
    elements can be used to control the soft type which will be used
    when new objects are created in Windchill. This setting will only
    be used if the equivalent DTD/Schema-specific setting is absent.
    The 'default' attribute must specify a fully-qualified
    soft type name which derives from DynamicDocument
    (which is a built-in type deriving from EPMDocument).
    The format of this attribute is as follows:
    wt.epm.EPMDocument|<child-name-1>| ... |<child-name-N>
    Each component must specify the 'Name' of each soft type
    (not the 'Display Name') as given in the Type Manager
    interface. An example 'default' attribute value follows:
    wt.epm.EPMDocument|com.acme.DynamicDocument|com.acme.CustomType
    <dmsobjtype default=""/>
    <dmsgraphicobjtype
    default="wt.epm.EPMDocument|com.irobot.DynamicDocument|com.irobot.Graphic"/>
    <!-- dmslocation
    A 'default' attribute value of "" indicates to use the home
    directory of the Context associated with the workspace the
    user selected during login.
    <dmslocation default="">
    </dmslocation>
    <dmsgraphiclocn default="/Wilsonville Products/User Documentation"/>
    <defaultnamecriteria>
    <namerule rule="division-head-content"/>
    <namerule rule="element-content"/>
    <namerule rule="element-name"/>
    </defaultnamecriteria><?Pub Caret -2?>
    </createdefaults>
    bookmap.bcf
    <!-- createdefaults
    NOTE:
    files to work.
    useroverride="on">
    <dmsgraphicobjtype
    <!-- dmslocation
    </dmslocation>
    </createdefaults>
