11-Garnet
Feb 22, 2023 4:24 AM UTC
OIR Configuration to have multiple Life cycle templates
I need to configure OIR for change activity to have two lifecycle templates based on the value of an attribute.
the attribute is <Attr id="change_owningChangeItem"/> and it's value can either be "Change Implementation - xxxxxx"  or "Change Notice - xxxxxxx" where xxxxx number is generated by system.
if the value is "Change Implementation - xxxxxx" then LC needs to be "Change Implementation LC"
if the value is "Change Notice - xxxxxxx" then LC needs to be "PLM Change Notice LC"
HelesicPetr
Feb 22, 2023 7:19 AM UTC
Hi @LT_10104055
Here is an example how to crate OIR rule with conditions where are used equaltest and substring
CS20322
this article describes how to set folder destination but it can also be used for lifecycle template.
This can help you to achieve what you need.
generally if first  21 chars are "Change Implementation" use LC A otherwise LC X
PetrH
HelesicPetr
Feb 22, 2023 7:11 AM UTC
Hi @LT_10104055
Do you know how to crate OIR rule conditions?
PetrH
11-Garnet
Feb 22, 2023 7:18 AM UTC
Yes, but for this requirement I am unable to create one
HelesicPetr
Hi @LT_10104055
CS20322
PetrH
