Dec 8, 2014 3:03 PM UTC
OIR default string value
I'm trying to learn how to set up OIRs and I ran into a problem.
I'm setting up a Part subtype, Vendor Part, with a standard soft attribute acme.vendor.VendorPartComment as a multi-line string. I want the new part wizard to display "No comments yet." by default.
Currently, my OIR for the Vendor Part contains the following pertaining to the comments:
<AttrValue id="acme.vendor.VendorPartComments" algorithm="wt.rule.algorithm.StringConstant">
<Arg>No comments yet.</Arg>
</AttrValue>
<AttrConstraint id="acme.vendor.VendorPartComments" algorithm="com.ptc.core.rule.server.impl.GatherAttributeConstraints">
<Value algorithm="com.ptc.core.rule.server.impl.GetServerPreGeneratedValue"/>
</AttrConstraint>
I'm using the same logic for the part name, and the wizard is displaying a default name correctly, but not this comment. The only difference between the two that I see is that the comment is displayed as a multi-line string vs a single-line string for the name.
Furthermore, the "No comments yet." appears after I create a vendor part, just not in the creation wizard.
Any suggestions?
SK
Dec 8, 2014 8:03 PM UTC
Hi Sergei,
Interesting issue.
I am wonder what is displayed in the wizard for this attribute?
Also how the constraints compare between name and comments in the type attribute manager.
Jarrett
Dec 8, 2014 8:33 PM UTC
Jarrett,
In the wizard, the attribute value is blank.
In the type and attribute management, the constraints are the following:
  • name
    • Single-Valued
    • Required
    • String Length from: 0 to: 60
  • acme.vendor.VendorPartComments
    • String Length from: 0 to: 4,000
    • Single-Valued
Dec 10, 2014 4:01 PM UTC
I was unable to find a solution through OIR, so in this case I would have to do it through
Type and Attribute Management, attribute settings, Default Values set to "No comments yet."
I just wanted to see if I can do it through the initialization rules XML, but I can't find a way.
23-Emerald II
Dec 13, 2014 12:59 AM UTC
What if you specify it as an IBA in the XML?
For example, I have the following set in one of my OIRs that sets the value for my XPOSASSY attribute to "Default":
<AttrValue id="IBA|XPOSASSY" algorithm="wt.rule.algorithm.StringConstant" ignore="false" force="true" final="false">
<Arg>Default</Arg>
</AttrValue>
Dec 15, 2014 1:49 PM UTC
Lori, do i need to change anything about my attribute in Type and Attributes administration?
It doesn't seem to be working for me.
