Jan 28, 2025 4:54 PM UTC
OIR - NUMBER GENERATOR
I am using Windchill PDMLink Release 12.1 and Datecode with CPS 12.1.0.1
How to set a different number ( concatenation of attributes) according to a different IBA value ?
HelesicPetr
Jan 31, 2025 1:44 PM UTC
Hi @FL_12115481
You have wrong test element.
Because there are two different types - string and Boolean the calculation can not be done by this Test method
You have to use the StringEqual test and it will work as you need
example>
<VarDef id="GeneratedNumberConfigurable" algorithm="com.ptc.windchill.enterprise.revisionControlled.server.impl.NumberGenerator">
	<Attr id="STRINGINPUT"/>
	<Attr id="RNUMINPUT"/>
	<Arg>{GEN:wt.enterprise.SequenceGenerator:WTDOCUMENTID_seq:3:0}</Arg>
</VarDef>
<!-- set the number to a generated number -->
<AttrValue id="number" algorithm="com.ptc.windchill.enterprise.revisionControlled.server.impl.NumberGenerator">
	<Arg>30W</Arg>
 <!-- add a V prefix for variant parts -->
 <Value algorithm="wt.rule.algorithm.BooleanBranch">
	 <Value algorithm="wt.rule.algorithm.StringEqualsTest">
		<Attr id="UTC_CONFIGURABLE"/>
		<Arg>true</Arg>
	 </Value>
		<VarRef id="GeneratedNumberConfigurable" />
		<Arg>{GEN:wt.enterprise.SequenceGenerator:WTPARTID_seq:10:0}</Arg>
 </Value>
 <!-- the sequence -->
 <Arg></Arg>
</AttrValue>
The real number input also works
PS: the error is clear. You compare boolean type value true with string value "true" and the method can not do that.
That is why the method throws the error "there are two different type arguments".
PetrH
Jan 28, 2025 5:56 PM UTC
In this example, I read the value of an IBA named Document_Type and set the prefix for two different values,
If the value is not one of those two, I don't prefix.
<!-- generate the number -->
   <Value algorithm="wt.rule.algorithm.CaseBranch">
<Value algorithm="wt.rule.algorithm.EqualsTest">
<Attr id="IBA|Document_Type"/>
<Arg>Bill_of_Material</Arg>
</Value>
<Arg>BOM-</Arg>
<Arg>Deviation</Arg>
</Value>
<Arg>DEV-</Arg>
<Arg></Arg>
   </Value>
   <Arg>{GEN:wt.enterprise.SequenceGenerator:WTDOCUMENTID_seq:10:0}</Arg>
   </AttrValue>
Jan 29, 2025 7:46 AM UTC
Hello mwaite, thanks a lot for your answer.
The problem I am facing is how to combine multiple attributes in the EqualsTest algorithm. If I try to insert more than one ARG Tag the system gives me an error. Apparently with the boolean branch algorithm you can just set a preferix or a different progressive number.
Below an example to make it more clear :
     <Attr id="IBA|UTC_CODICESIMILE"/>
     <Attr id="IBA|UTC_MOD"/>
</VarDef>
                  <Arg>30W</Arg>
                        <Attr id="IBA|UTC_CONFIGURABLE"/>
                        <Arg>true</Arg>
                     </Value>
                       <VarDef id="GeneratedNumberConfigurbale"/>
                  </Value>
                  <Arg></Arg>
               </AttrValue>
HelesicPetr
Jan 29, 2025 8:06 AM UTC
Hi @FL_12115481
By the Boolean branch you can add more attributes. but you just need to repeated the Boolean branch as an another condition
btw in the boolean branch never ever leave empty rows...
	<Arg>30W</Arg>
		<Arg>true</Arg>
		</Value>
		<Arg>FIRST ARG IN THE CONDITION</Arg> <!-- true -->
		<Arg></Arg> <!-- false - nothing to add-->
	</Value>
			<Arg>true</Arg>
		</Value>
		<Arg>NEXT ARG IN A ROW...</Arg> <!-- true -->
	</Value>
			<Arg>true</Arg>
		</Value>
		<VarDef id="GeneratedNumberConfigurbale"/> <!-- true -->
		<Arg>{GEN:wt.enterprise.SequenceGenerator:WTPARTID_seq:10:0}</Arg> <!-- false - generate the auto number-->
	</Value>
</AttrValue>
PS> please share the error that was thrown in your case.
PetrH
