Jan 23, 2024 7:05 AM UTC
OIR - Numbering Logic
Hi Guys,
I want to know if we can merge the attribute values to create a single attribute.
For example, I created a WT part.
I filled out the attribute number 8989, created and added the customer number attribute in WT, and selected it from the drop-down list. I also manually entered the project number for one more attribute. Everything I get into the Number attribute. Is it possible to do it through OIR?
Aj
Rocket_Max
Jan 23, 2024 7:24 AM UTC
Take a look at this article, which covers a lot of OIR settings
Article - CS172537 - [Knowledge Hub] Windchill PLM - Object Initialization Rules (OIRs) (ptc.com)
Jan 23, 2024 8:32 AM UTC
Thanks Rocket,
I discovered that. Now I am looking for the same number and name.
Aj
Jan 24, 2024 4:40 AM UTC
Find the below OIR
