7-Bedrock
Oct 2, 2018 4:38 PM UTC
OIR rule to auto file base on number,
Dear All
I am currently testing some OIR ideas for our Windchill 11.1 installation and would be great full for some assistance
We file our Production CAD and WTparts based on the first 2 characters of the number in the past we have done this manually
I have been working on the below script which will correctly file the part based on first 2 characters but I need to add around 1000 repeats of the code to cover all the options.
Is there a way to make the substring extracted value to an attribute then use it to build the folder.id
<AttrValue id="folder.id" algorithm="com.ptc.core.foundation.folder.server.impl.FolderPathAttributeAlgorithm"
   ignore="false"
   force="false"
   final="false">
<Value algorithm="wt.rule.algorithm.CaseBranch">
<Value algorithm="wt.rule.algorithm.StringRegExEqualsTest">
<Value algorithm="wt.rule.algorithm.Substring">
<Attr id="number"/>
<Arg>0</Arg>
<Arg>2</Arg>
</Value>
<Arg>51</Arg>
</Value>
<Arg>/Default/FV5/1</Arg>
<Attr id="number"/>
<Arg>0</Arg>
<Arg>2</Arg>
</Value>
<Arg>52</Arg>
</Value>
<Arg>/Default/FV5/2</Arg>
<Attr id="number"/>
<Arg>0</Arg>
<Arg>2</Arg>
</Value>
<Arg>53</Arg>
</Value>
<Arg>/Default/FV5/3</Arg>
<Attr id="number"/>
<Arg>0</Arg>
<Arg>2</Arg>
</Value>
<Arg>54</Arg>
</Value>
<Arg>/Default/FV5/4</Arg>
<Arg>/Default/Default_Directory</Arg>
</Value>
</AttrValue>
<AttrConstraint id="folder.id" algorithm="com.ptc.core.rule.server.impl.GatherAttributeConstraints">
                   <!-- Value algorithm="com.ptc.core.rule.server.impl.GetServerPreGeneratedValue"/-->
                   <Value algorithm="com.ptc.core.rule.server.impl.GetImmutableConstraint"/>
           </AttrConstraint>
</AttributeValues>
Jul 25, 2019 8:41 PM UTC
I don't think we have any easier way to achieve this using the OOTB algorithms. I would recommend creating a custom algorithm class which would do the processing for you and return the appropriate result.
Following article can be referred to understand how a custom algorithm can be developed.
https://www.ptc.com/en/support/article?n=CS110198
Also refer to following JavaDoc for more details:
http://support.ptc.com/cs/wncdoc/110/wcapi/wt/rule/algorithm/RuleAlgorithm.html
Hope this helps.
Mayur
