Dec 27, 2015 12:29 PM UTC
On a rehosted Windchill 10.x system MethodServer fails to start with error "Info*Engine configuration error - The default Directory Service Provider URL and/or Service Search Base could not be retrieved from Info*Engine properties."
Hi All,
I am Rehosting(Rename) in Windchill 10.2 M030 using Rehosting Utility 3.0,
I have tried in Test server its succesfully rehosted, however i am doing the same in Production Server,Methods server couuld not able to start.
Below is the errors,
  • On a rehosted Windchill 10.2 system the MethodServer fails to start with the following error message:
wt.method.server.startup.services  - Failure to start manager wt.audit.StandardAuditService
wt.services.ManagerException: Could not initialize Auditing service.
Nested exception is: wt.util.WTException: (wt.federation.PrincipalManager.PrincipalManagerResource/CONFIG_ERROR_INCORRECT_NAMING_PROVIDER) com.infoengine.util.IEException: Info*Engine configuration error -  The default Directory Service Provider URL and/or Service Search Base could not be retrieved from Info*Engine properties. Contact your system administrator.
Nested exception is: (wt.federation.PrincipalManager.PrincipalManagerResource/CONFIG_ERROR_INCORRECT_NAMING_PROVIDER) com.infoengine.util.IEException: Info*Engine configuration error -  The default Directory Service Provider URL and/or Service Search Base could not be retrieved from Info*Engine properties. Contact your system administrator.
at wt.federation.PrincipalManager.DirContext.getAdapterInfoMaps(DirContext.java:313)
at wt.federation.PrincipalManager.DirContext.initMapsForDefaultAdapters(DirContext.java:273)
at wt.federation.PrincipalManager.DirContext.init(DirContext.java:248)
at wt.federation.PrincipalManager.DirContext.getPrimaryName(DirContext.java:631)
at wt.org.LdapServices.getAllServices(LdapServices.java:304)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:606)
  at wt.services.ServiceFactory$ServerInvocationHandler.invoke(ServiceFactory.java:399
Please help me out.
regards
Mahesh Kumar G
2-Explorer
Dec 27, 2015 10:56 PM UTC
I think there the rehost script did not completely modify the LDAP conf branch and the info*engine property files. Quickly browse through the ie/properties file in Windchill/codebase/WEB-INF directory and the conf branch in LDAP.
You can try running the ant script to make sure that the LDAP details are correctly modified to match new server name.
From Windchill/ bin/adminTools/rehost/
ant "-Dtarget-ldap=ldap://<LDAPAdminUser>:<LDAPAdminPW>@newservername-fqdn:<ldapPort>/" -Dtarget-domain=newservername-fqdn
Thank you,
Binesh Kumar
2-Explorer
Thank you,
Binesh Kumar
Dec 30, 2015 12:17 PM UTC
Hi Binesh,
Thanks for your reply, I have resolved using the same.
Thank you
Jan 19, 2018 11:10 AM UTC
How the issue solved plz let me know.. i am facing same issue
