Oct 12, 2023 6:19 PM UTC
Only show latest revision of part instances?
We have a tab that shows part instances (serial numbers). When I revise the instance so that it matches the current state of the wtpart (Rev from - to B for example), the part instance tab will show the same serial number and list both revisions. Is there a preference to only show the latest?
Community Moderator
Oct 20, 2023 4:48 PM UTC
Hi Aaronm87
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Anurag
