Feb 22, 2017 6:02 PM UTC
OOTB improvement on Xliff creation to make this execute in parallel
Main Translation Process Bottleneck – Reasons
  • Increased volumes of parts books to be translated
  • 2nd or 3rd translation package needed to completely translate media
  • Significant amount of translation requests for just a single language
Additional translation requests - Reasons
  • Authoring process „exceptions“ causing need for retranslation
  • Production partlists being iterated (e.g. to add / change modifiers)
  • Production media being renamed (e.g. OMM name updates)
  • Publishing failing if no new Xliff is generated and translated (for partlist or media)
  • Media baseline used in publishing doesn‘t reference the modifier objects – so always using latest (with changed name / modifierString)
  • Media rename doesn‘t iterate the object, so media baseline still valid, but information that was exported and translated through the Xliff is outdated
  • In both cases Translation Dictionary doesn‘t have translation for latest strings, therefore publishing fails
  • Current „process“ is to manually force creation of new Xliff (Support staff)
  • Support staff must force Xliff regeneration
  • Translation staff must request new package for whole media (even if just one partlist Xliff might have been updated)
Improvement Request
  • Improve Management by throttling thread pool size for Main Translation Workflow queue
    • Avoid MethodContext threshold being exceeded to avoid periodic stack trace
    • Won‘t improve performance (stack trace only adds a few 1/10 seconds)
  • Improve processes to avoid 2nd/3rd translation request for whole media
  • Improve processing performance of Xliff generation (taking up most of the time spent in Main Translation Workflow)
    • Refactor publishing customizations to separate code necessary for Xliff generation from code necessary for PDF / SISWeb publishing
    • Reduce custom metadata processing for Xliff generation to the absolute minimum required to get all custom attribute values for translation
  • OOTB Change to support parallel execution of Xliff generation
nslation Queue issue
Emeritus
Feb 28, 2017 8:22 PM UTC
Good day STEN OLSEN‌ - is this supposed to be a product idea?
If so, would you please enter each as a new idea?  Doing so makes them easier to triage and organize.
Please let me know if you have any questions or need assistance submitting new product ideas.
Thank you,
Toby
