8-Gravel
Dec 6, 2024 6:18 AM UTC
OOTB to disable creating CN on an object which is present in the resulting objects of another CN
Hello, is there any OOTB functionality to disable creating a Change Notice on a version of an object which is already present in the Resulting Objects of another Change Notice?
Because it can be quite a common business requirement that if there is an ongoing change on an object, I don't want to add another change on it before completing one change.
Om Panchdhane
Fadel
23-Emerald II
Dec 9, 2024 5:20 PM UTC
when an object is under change you have a flag for it :
if you have an issue with concurent changes, you may be interested in About Redline
Buiꓘa
8-Gravel
Dec 9, 2024 5:28 PM UTC
But we can still create another change notice on it right? Is there any configuration to disable the CN creation?
Fadel
23-Emerald II
Dec 9, 2024 5:34 PM UTC
Not OOTB , I can only think of customizing the the CN/CT workflow to move the affected objects to Lifecycle state with a set state robot to a state   where there is no change transition, defined , this should hide the action .
Buiꓘa
