May 1, 2024 4:39 PM UTC
Optical Character Recognition (OCR) and Windchill PLM
Version: Windchill 12.1
Use Case: One of my client is looking to use Windchill search for scanned documents. It looks like Windchill Search cannot do optical character recognition (OCR).
Description:
Does anyone has experience with using a third party OCR with Windchill? TIA
May 2, 2024 8:48 AM UTC
Article - "Does Windchill support Optical Character Recognition (OCR) of text in document images?": https://www.ptc.com/en/support/article/CS364005
May 2, 2024 2:30 PM UTC
Thank you for the link, I know that OCR is not supported by Windchill search. Is there a workaround to get OCR working with Windchill? I saw Amazon has a product called Textract, has anyone used it with Windchill? TIA.
HelesicPetr
May 6, 2024 5:59 AM UTC
Hi @ajay252508
I can imagine, that if you create own search wizard, and you find some java OCR library then you can write a code to use the OCR utility in Windchill.
PetrH
Community Moderator
May 13, 2024 10:22 PM UTC
Hi @ajay252508,
I wanted to follow up with you on your post to see if your question has been answered.
If so, please mark the appropriate reply as the Accepted Solution.
Of course, if you have more to share on your issue, please let the Community know so that we can continue to help you.
Anurag
