Jun 8, 2023 5:20 PM UTC
Option to allow part data to load with missing required fields
When using Partslink and defining some attributes as required, we are unable to load legacy data that might be missing some of this data.  Is there a setting we change that allows the part data to be loaded (via importable spreadsheet) if it is missing required information?  The premise here is to get the legacy data in but prevent new parts from being created without the required data.
Thanks!
Fadel
FadelAnswer
23-Emerald II
Jun 9, 2023 7:35 AM UTC
Hi , right now no constraints are applied when loading data from spreadsheet :
https://www.ptc.com/en/support/article/cs268690
Buiꓘa
Fadel
Fadel23-Emerald IIAnswer
23-Emerald II
Buiꓘa
Jun 9, 2023 12:17 PM UTC
We are not seeing this be the case.  We have some required numeric values and they are failing to load.
I will confirm that this is the case and provide the errors we are getting.
